- 29 Jul 2004
Which setting on is the PSU supposed to be on for the correct voltage, with the 115 or the 230 showing? Isnt very clear at all!
Stupid question but rather get it right and switch it over so the 230 is visable before i put it in the pc!
The voltage that you want it to run at must be showing e.g. in the UK, it should be showing 230.
quite shocking that it came pre set as 115 had i not checked it first.
As above. Do not think that because the 115 voltage is lower than uk 230V that it will do no harm to your system (in case curiosity got the better of you like it did a friend of mine)
