The usual checks - make sure everythings hooked up hardware-wise, especially the power connecters to the mobo and all thos graphics cards. Power could be the issue, especially with those 3 graphics cards.
Next make sure all the lates mobo, chipset, sound and graphics drivers are installed. This is unbelievebly important. And then as suggested above, look at updating the mobo bios. Make absolutely sure you flash the correct bios to your mobo. Read the guides, google it, research it upside down and inside out. Time consuming, but done once you'll know how to do it in the future. It can fix problems.
Best of luck dude!
