iPhone and iTunes Issue
20 Sep 2003
Scotland
I have the latest iTunes installed on my PC and when i connect my iPhone is recognises it etc. So o create a new playlist in iTunes and add my music to it. Then click the songs tab in the iPhone menu, then select the playlist I want to add. But when i look back at my iPhone it has deleted all my previous music from the phone :(
What am I doing wrong?
Thanks,
Dez.
If your doing it like that you need to make playlists for all the music you want on your iPhone i think.
What's the alternative?
You can select to manage your music manually and drag your music across. You mite be able to drag playlists over too, you will have to try it.
I have not got my usb cable with me so i can't check.
Edit: Meh beaten to it ^^
