Well it is hotlinked, but I would have thought the mods would have removed it instead of just warning![]()
What is hotlinking?
I think you'll find there has been a number of 777s that have had issues with both engines not responding......![]()
Shhhh - I'm going to be on a 777 for 8 hours tomorrow night!
<Princess Leia> "Would it help if I got out and pushed?" </Princess Leia>
What is hotlinking?
Just to make you all scared, it has! With varied results! An A330 ran out of fuel over the Atlantic due to a fuel leak, it glided 220miles and landed in the Azores. A 747 had all 4 engines flame out after flying through volcanic ash, it descended to around 6000' or so before it got 2 of its engines running again and it diverted and landed safely. A 767 ran out of fuel again and glided to land at a disued airfield in Canada.
I could go on......Don't you love Air Crash Investigations on National Geographic![]()
Linking images directly from the source instead of uploading to a dedicated host such as Imageshack.
There's a couple of problems with hotlinking; firstly it eats up the sites bandwidth and secondly if the source image changes so does the one posted. Especially the case with Wikipedia - if someone changed that image to something quite unpleasant it would also appear in your post!
If you hotlink an image and it turns bad, we will suspend you for it. That's why we have a blanket ban on hotlinking to anything other than known image hosting sites.Ah I see, so is it actually baned here?
isnt air travels supposed 2 be the safest out the other travel ?
Correct![]()
No, it isn't debateable. It is statistically one of the safest methods of travel. Total engine failure is a rare event, especially on a multi engined aircraft.But if your engine fails you can't just pull over. It's debatable because you're not actually in control of the vehicle so your trust is with the pilots.
Ok I agree that statistically it is the safest but the fact is that you can't do anything if something does go wrong where as other forms of transport that are statistically less safe you might be able to.
Designed for small city airports yes.
Steep glideslope and short runway.
