GeForce 175.12's for Vista 64bit all cards
Unless you have an Nvidia chipset
Oh yeah forgot about that, i wouldn't use it if you have a Nvidia chipset as it removes your LAN driver as well (something to do with it being named the same/similar), so id just use DriverCleaner pro still until thats fixed, which is supposed to be the latest version thats due. :)
No they aint shafted 8000 users.
I set it up the drop down boxes for 8000 series (defaults to 8800Ultra+ Vista32) and changed it to Vista64 and got them.
Im happy they finally added the CRT settings to Vista drivers (the parts I made BOLD).
Supports GeForce 6, 7, 8, and 9 series GPUs including these newly released GPUs:
GeForce 9800 GX2
GeForce 9800 GTX
GeForce 9600 GT
GeForce 8300
GeForce 8200
GeForce 8200/ NVIDIA nForce 730a
GeForce 8100/NVIDIA nForce 720a
Supports single GPU and NVIDIA SLI™ technology on DirectX 9, DirectX 10, and OpenGL, including Quad SLI technology with GeForce 9800 GX2 and 3-way SLI technology with GeForce 9800 GTX.
Adds new PureVideo HD features for GeForce 9800 GX2, 9800 GTX, and 9600 GT:
Dynamic Contrast Enhancement
Dynamic Blue, Green & Skin Tone Enhancements
Dual-Stream Decode Acceleration*
Microsoft Vista Aero display mode compatibility for Blu-ray & HD DVD playback*
Added the following pages to the NVIDIA Control Panel:
Manage Custom Resolutions
Adjust Television Color Settings
Adjust Screen Size and Position
Move CRT Position
Improved performance on many DirectX 9, DirectX 10, and OpenGL applications.
Numerous game and application compatibility fixes. Please read the release notes for more information on product support, features, driver fixes and known compatibility issues.
Strange, i don't get that here, i just get :-
WHQL Certified driver for the following GPU's
* GeForce 9800 GX2
* GeForce 9800 GTX
* GeForce 9600 GT
* GeForce 8300
* GeForce 8200
* GeForce 8200/NVIDIA nForce 730a
* GeForce 8100/NVIDIA nForce 720a
Im well confused here, can someone put a direct link to them please, as i cant find them searching the UK site here, under the WHQL search i get the 174.74's for the 9 series under Vista, and the old 169.25's under XP for the 8's, and the Beta section switches it to the Amercian site, and only the 174.74's are found.
Yet the direct links posted in a thread on Guru take me to the 175.12's, but they only say this :-
WHQL ceritified driver for the following GPU's.
* GeForce 9800 GX2
* GeForce 9800 GTX
* GeForce 9600 GT
* GeForce 8300
* GeForce 8200
Heres the direct link to the Vista 32bit set :- http://www.nvidia.co.uk/object/winvista_x86_175.12_uk.html
Vista 64bit set says the same.
As you can see, no mention of 8800's anywhere. :confused:
EDIT: ahh just found them, when i switch the language to English UK. :p, but they just say the above, that they are only for the 9 series, but they do come up under 8800's search, wtf. :D
was baffling that, still no good to me being on XP, knew we wouldn't get a set released yet.:(
GeForce Release 175.12 BETA - VISTA 64BIT LINK ONLY. (OTHER OS LINKS ON NVIDIA WEBSITE)
http://www.nvidia.com/object/winvista_x64_175.12.html
EDIT: FULL LIST OF SUPPORTED CARDS
GeForce 9800 GX2
GeForce 9800 GTX
GeForce 9600 GT
GeForce 8800 Ultra
GeForce 8800 GTX
GeForce 8800 GTS 512
GeForce 8800 GTS
GeForce 8800 GT
GeForce 8800 GS
GeForce 8600 GTS
GeForce 8600 GT
GeForce 8600 GS
GeForce 8500 GT
GeForce 8400 GS
GeForce 8400 SE
GeForce 8400
GeForce 8300 GS
GeForce 8300
GeForce 8200
GeForce 7950 GX2
GeForce 7950 GT
GeForce 7900 GTX
GeForce 7900 GT/GTO
GeForce 7900 GS
GeForce 7800 SLI
GeForce 7800 GTX
GeForce 7800 GT
GeForce 7800 GS
GeForce 7650 GS
GeForce 7600 GT
GeForce 7600 GS
GeForce 7600 LE
GeForce 7500 LE
GeForce 7350 LE
GeForce 7300 SE
GeForce 7300 LE
GeForce 7300 GT
GeForce 7300 GS
GeForce 7200 GS
GeForce 7100 GS
GeForce 7150 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 630i
GeForce 7100 / NVIDIA nForce 620i
GeForce 7050 / NVIDIA nForce 630i
GeForce 7050 / NVIDIA nForce 610i
GeForce 7050 PV / NVIDIA nForce 630a
GeForce 7025 / NVIDIA nForce 630a
GeForce 6800 XT
GeForce 6800 XE
GeForce 6800 Ultra
GeForce 6800 Series GPU
GeForce 6800 LE
GeForce 6800 GT
GeForce 6800 GS/XT
GeForce 6800 GS
GeForce 6800
GeForce 6700 XL
GeForce 6610 XL
GeForce 6600 VE
GeForce 6600 LE
GeForce 6600 GT
GeForce 6600
GeForce 6500
GeForce 6250
GeForce 6200SE TurboCache™
GeForce 6200 TurboCache™
GeForce 6200 LE
GeForce 6200 A-LE
GeForce 6200
GeForce 6150SE nForce 430
GeForce 6150 LE
GeForce 6150
GeForce 6100 nForce 420
GeForce 6100 nForce 405
GeForce 6100 nForce 400
GeForce 6100
ive got a 9800gtx , the 174.74 install fine, the 175.12 32 bit version wont, says cant find any drivers that are compatible with your hardware, bizzare.
