So guys basically I thought I would download the Fakefactory Mod for HL2 and I have encountered problems when using it
Unfortunately I can only get through the first instance of the intro just until Barney lets you out of the "interogation" chamber and then when it gets to the loading screen just after it......crash!
Now I see there is a problem or unsupported thing for 32bit which is what I am trying to use so does anyone have a work around for this at all? I am trying to play it on Vista so is there greater success on XP?
If you have any advise/settings it would be great
RodgA
Now I see there is a problem or unsupported thing for 32bit which is what I am trying to use so does anyone have a work around for this at all? I am trying to play it on Vista so is there greater success on XP? If you have any advise/settings it would be great
RodgA
