Hi guys, ive only just discovered the joys of R-Factor, been away from PC gaming for quite a while and im impressed with how many of the PC games support triple monitors (as a racing game fan). This has got me thinking and seeing many You Tube videos wet my appetite.
Ive had a 3way desktop years ago and im aware of how to go about it in general. The questions i have is for games like R Factor/GT2/TDU and possibly the upcomming GRID.
Im assuming because 3 screens are needing powered i would be best with some card that supports 3+ displays as i cant use SLI with more than 1 display. Thinking on framerates here. The problem then is having a card that is powerfull enough and supports 3 displays, or can SLI (possibly 2x 880GT) be used with that Matrox thingy, ahhh ermmm? Or can i just get a card like the ASUS Top 3870x2 that supports 4 displays.
My system is pretty mid range on the CPU side.
AMD 6000+ with 4GB Vista Ultimate
I would like to obtain high detail if not MAX detail on even the new GRID game if possible via 3x screens. The only benifit is i will likely be running 1280x720x3 = 3840x720 Res with some AA etc.
This is still a lot less than say a 30" Monitor uses with 2560x1600 and slighly more taxing than what a single 24" display uses so im assuming with a good card setup i should be ok on the frame rate issues?
This new project will actually be using 3x Hi-Def projectors (in process of finding 3rd) rather than monitos as im wanting big screen sizes and to avoid the monitor frames in between each display. Each projector will be set so theirs no screen gaps or ovelapping and are likely only to be 32-40" each.
Idea is to have some form of slightly arched screen to create a more wrap around field of view.
Appreciate any help or tips with the mentioned games and multinonitors and usage with Track IR
