oh sorry the budget is £1,000 pref but will go slightly over.
After a fair amount of research we went with the Panasonic 50px70 and was just over £700. We are really chuffed with it but then we don't use blu-ray or anything like that, just freeview.
A few question though:
1. What is your viewing distance ?
2. How long before you want to buy ?
2, because the new pioneers will be out around june time and might be waiting for to see their pricing and if panasonics may drop a little.
the distance is around 5 foot max, and looking to purchase in the next week/two
Don't bother looking at LCD tvs, plasma is the only choice when the majority is sky/freeview etc and films, better balcks, smoother motion, and jsut a much richer and more peachy picture.
Spoken like a true Plasma owner![]()
I've recently been looking into a new flatpanel. A friend has the Sharp 46" 2LE LCD screen. Its £999, great freeview/sky picture, Blacks are fantastic (equal to his old Panasonic 42" Plasma) True 24P and 100Hz so smooth motion and a vibrant picture.
And 1080p.
Of course ! I did spent 2 long months comparing tvs and eventually found the best. But most importantly all over them looked very different in *** varies shops I tried, so needed a lot of setting up to srot out the picture
I would say go to specsavers, or compare 2 well setup sets side by side, then you will see the truth
Vibrant picture does not mean accurate though![]()
but if you have your heart set on a 50 inch then look no further than the panasonics. Also check out the new 46 PZ85 (or was it PZ80, can' rememebr this early in mroning). Haven't seen this tv, but I had its predecessor reserved and ready to be bought as it was soo good
The marketing says LCD can be as good if not better overall than Plasma.
