Kylew, dont wanna go off topic but just a quick note to say its easier to read your posts if paragraphed, also may get you replies faster.
What motherboard are you using? not a 680 or 780i I hope...
ive been getting roughly the same problem as yours since december when i built the pc, but not as many BSOD,s as you though, two to be exact, but the graphics driver stopped working message while playing game (atikmdag.sys problem) or TDR as they call it....anyways ive done a lot of research and veiwed over a thousand posts about this very common problem without finding any real solution, a lot of peeps who have the problem have tried changing gfx cards,memory,psu,s and even operating systems to try and get rid of the problem, but it comes back in different forms i.e more bsods or more crashes,less freezing and so on, but its still frustratingly there
The thing that stopped my gfx driver has stopped working message, was the hotfix for the 8.3,s but instead i get system lock-ups or freezing (requiring reboot) tbh i dont know which is worse
I generally believe it is a driver issue but im not 100% and the reason im not totally sure is it happens with nvidia aswell as ati and also both xp and vista, so who knows.......google atikmdag.sys and see the amount of poeple that have a similar problem to you and also the amount of time it has been a problem (over a year now) ..... sorry i havent helped much, but i thought i would let you know your not alone with this atikmdag.sys problem, as for me i will keep updating drivers in hope it will sort it (even though i havent tried 8.4,s yet) ill download them tonight, you never know it may fix it!! but i wont hold my breath![]()
. The worst thing about it is that it just randomly happened one day. I hope this will sort it out anyway.
 just a friendly comment, I hope you don't take offence to it
.OK, give those drivers a go mate, if that fails, get an RMA out for the card, if not, I'd be willing to bet it's the RAM, do try and run memtest, orthos usually picks up fault ram, but memtest is the real way of telling for sure. It solved MONTHS of rma's etc. with my rig.
Whats your RAM voltage ?
Has already been suggested further up! It's common place these days that boards undervolt the ram.
Not using a Belkin are you - mine caused some very strange problems - even tripped the ring main from time to time!
Thats great news! Glad to hear your up and running, playing games again![]()
