- 2 Aug 2005
- Cleveland, Ohio, USA
Hello Gents. I've had a nagging problem with my engine for quite some time now and none of my efforts seem to have found a remedy yet. I'm writing here in case one of you can come up with something I haven't thought to consider.
In short, I have preignition/detonation problems with my Pontiac 400. In it I have a relatively mild cam and an AFB-style Edelbrock 750 CFM carburetor. The ignition advance is set to a reasonable amount. It runs about 9.5:1 compression and I always use 92 octane fuel. The engine used to run too hot for my liking but I cured this with a new, gigantic 2-row aluminum radiator and a pair of meaty electric fans on an electric thermostat. I now have about 5k miles on the rebuilt engine.
When it gets up to operating temperature, about 185°F (85 C), it exhibits detonation under partial throttle, between 1/4 and 1/2 open, especially when under load like going up a steep hill. It's fine at idle and, mysteriously, it's also fine at WOT. The spark plugs look great when I've inspected them; a healthy shade of light brown.
I have been able to cure this problem by advancing the timing to about 0°, but then it doesn't run worth a crap; insufficient vacuum, poor idle quality, and seriously reduced performance. I've taken it to three experts, none of whom have been able to exercise its demons. They've all said that it seems to check out OK with the sole exception of the detonation. I even used a boroscope to look inside the combustion chambers for metal chips, piston/head/bore damage, or other forms of scarring that might be creating hot spots. No such luck.
Any ideas? Anything I should check out?
I don't really know much about tuning the electronic one though. I know there's an electronic module inside that does something or other.
Presumably it's a multi-spark ignition box like MSD sells?
