Arctic Cooling Accelero S2 VGA Cooler question
Normally psu's extract some air from the case even if you dont have a separate. how much varies a lot, check you psu for a big fan and vents for air to be sucked out of the case!
Fans can easily be added if you case allows (prefferably add one blowing in the fornt or side and one blowing out the rear or top) or you could look for a vga cooler that blows outside the case such as this 2 slot wide card
http://www.overclockers.co.uk/showproduct.php?prodid=HS-044-AK&groupid=701&catid=57&subcat=787
Surely your case has a place for a fan or 2?
Measure up and get a few when your order the S2
Surely I will.
One question though. Errata says that one fan should be sucking air in, and one out. I have the psu, cpu and a seperate fan all blowing out. Why is there a need for one sucking air in?
