does it not say "catalyst version" just beneath that? (under information centre>graphics software)
and i can only assume you're asking this because you've installed drivers from a cd? if you had downloaded the latest version online, then you'd know anyway?![]()
why did you even bother with the cd? you should have just downloaded the latest version online. i know this doesn't answer your question but i don't really think there is any easy answer. maybe google it?
i believe there is a 8.4 hotfix for agp cards. try that. saying that i've never had any problems when i had an agp x1950pro. the problems seem to be very random.![]()
the hotfix is a complete package. you don't need the 8.4s installed.
http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=31542
