Well i tried the settings as per photos/suggestions and it simply wouldnt boot.
With some experimentation about the best i have so far is 3.4ghz using the majority of your settings, but with the FSB set to 425 x 8. And the RAM at 5-5-5-18 2.10v (show DDR2 850), NB at 1.55v
Now what i am most worried about is that i have the CPU Voltage set to 1.55v (as it wouldnt start/BSOD, or wouldnt complete a 3dmark05 score at anything below this). With it set at 1.55 in the BIOS CPU-Z is reporting this at 1.480v idle in windows, running 3dmark this dropped to 1.44, but using stress test v6 this drops down as low as 1.384 at 100% load, which seems like quite a big drop.
Temps at idle are 40 degrees C, under 100% load this goes up to a maximum of 57, and the motherboard at 40. My not particularly well ventilated room is 26 so feeling quite warm, hopefully it wont get too much warmer in the summer.
Does all this seem quite reasonable, or at those volts/temps am i in danger of toasting something. Even more so, are there any suggestions for trying anything else to either try and lower the temps, or better still try and get this to the magical 3.6.
Thx in advance
Craig
Intel Q6600 G0
Asus P5kc
4 x 1GB Corsair XMS2 CM2X1024-6400 1 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-13 @ 270 MHz)
Processor water cooled in Thermaltake VE2000BWS
Nvidia 9800GTX
3 x 500GB 7200.11
