First Biped - 3D Max
11 Apr 2003
Notts
Hey all, as some of you may already of seen, I was tasked with creating a Biped with no more than 3000 Triangles, just wanted to update you all and show you what I have done. This is the first time I have created anything organic, and the first time i created my own face etc, textures:
Any feedback is welcome, positive or negative, thanks :)
Pretty good for a first go at organic stuff, it's always the hardest to try and capture human form, especially with 3k tris! Overall the proportions look great, the mouth looks a little strange as if shes pouting (maybe intended) and the fingers look a little off but even so, good work.
How did you unwrap it, did you use pelt mapping?
That's awesome :) I'm doing 3D programming with C++ and OpenGL as a hobby at the moment, but I have a lot of difficulty with the modelling side of it. More so than with the programming side of things! Maybe we could start some kind of joint project in a few months :D
Only criticism is I think the corners of her mouth should be raised slightly, make her look a little happier :p
Thanks, and yeah I probably should make her look a bit happier :D A joint project also sounds cool, I need things to give me more practice hehe!
