Computer turbo button
Capodecina
1 Aug 2005
Flatland
Whoever had one of these? My brother used to have a PC with a 'turbo' button on it, which would throttle the CPU from 8Mhz to a mind-meltingly fast 25Mhz.
Faster than the speed of thought.
Yep used to have one that went from 33 to 66 or something :D
Whoosh. They had them on all the cheap keyboards left over from the olden days when I started secondary school. Never had one at home.
Some of the old school cases too come to think of it.
So could you run it in 'turbo mode' all the time? or would it throttle back when it got a bit toasty?
That's what I never understood. Why just not always run it at 25? It was probably just a gimmick, rather than an extra boost that was available when running demanding applications like... Minesweeper.
I always thought it was for enabling or disabling the maths coprocessor? Hence the differences between an SX and DX machine - the latter one having the coprocessor the other not?
My turbo button got me from 8 -> 16MHz - I think it was 286 with 4MB of RAM :eek: I had a 10mb HDD, I was so leet in those days :D
Turbo mode was enabled to turn it off as some programs couldn't cope (timing loops etc...) with the fast speeds.
thought it was 8bit coding and it couldnt cope with 16bit "turbo mode"
im still drunk so could be waaaay wrong :p
Yeah my mate had one that toggled between 8mhz and 25mhz.
In the good old days when you had a LED display on the front of the case showing CPU speed.
Wikipedia said:
On personal computers, the Turbo button changes the effective speed of the system. It usually accomplishes this by either adjusting the CPU clock speed directly, or by turning off the processor's cache, forcing it to wait on slow main memory every time. The button was generally present on older systems, and was designed to allow the user to play older games that depended on processor speed for their timing. Systems could also use the keyboard combination of ctrl-alt-+/-, '+' switching turbo OFF and '-' switching it ON. Of course, calling it a "turbo" button when its function slows the system down can be a bit misleading, but the button was usually set up so the system would be at full speed when the button was "on". A turbo button is no longer seen on most mainstream personal computers.
It's just as well they got rid of the 'Turbo' button. If they hadn't I would have been compelled to blurt out "Vtec kicked in... yo!!!" or quote Captain Picard and declare "Engage." every time I pressed it.
When i was in college we found an old PC with one on, so we modded it and sprayed it, now it really does look like its a turbo pc :cool:
My understanding of the issue (and I'm old enough to have lived through when those machines were new) is that it was about compatibility of certain software. Default was Turbo on, but where older programs struggled you could turn the speed down by releasing the Turbo button.
M
M
As I remember it.
