E8400/8200 run cooler than E6420?
I have an E8400 that idles at 24C in a 20C room with a passive HR-01 heatsink, and loads out at 42C with the same cooler after 8 hours of Orthos. It runs so cool I can use my Zalman Reserator with it, even when it's overclocked to 4.25GHz it runs fully loaded at under 60C with two graphics cards in the same loop. It is a quite phenomenal CPU in my opinion.
thanks
I'd agree.
My chip in sig runs at the following temps (monitored by Realtemp):
Idle - 32c
Load - 49c
In comparison it's running cooler than my old e6600 did @ 3.4ghz and a lot cooler than my e2160 @ 3.4ghz.
Great chips.
gt
Well I will give you a perspective from a mATX system I have built spec in sig;
Mine runs at; (Stock Temps)
43c Idle
61c Full Load
That is using a Zalman CNPS8000 at 1500RPM it defiantly should be cooler than your E6420 anyway.
