Abit IP35 Pro Chipset Water Cooling
4 Sep 2007
Staffordshire
Hiya's,
Anyone got the whole of the abit ip35 pro water-cooled ??
I have my quad cooled with water but really want chipsets/mossfet areas done with water too
Can't seem to find a kit or even parts :(
Searched forum but throws up nothing really to do with what i'm after or throws me back to advanced search
Anyone here got chipsets watercooled on this mobo ??
Well hoping someone can point me in the right direction
Cheers
Ciao
Def
Good luck in finding one. I've had to jam a 60mm fan in on top of my PWN heatsink. Works really well tho
There are 3 places in the UK that do MIPS. They will not ship outside Germany without going through a dealer unfortunately, but there are several places that sell MIPS and will order stuff up for you.
They're pretty expensive for something that probably can't be carried over to another build.
The 60mm fan will do nicely -
Hiya's,
Yeah i've found all the blocks i need, and yes they're fairly expensive
Have got 2 brand new universal chipset blocks so i could use one of those for the NB and just get the mossfet and SB
Around 60 quid for those 2 delivered
I am going to get the 3 fan variant rad for my swiftech kit, and have both 3 and 2 fan rads in the loop
Well i got tomorrow to decide whether to order i guess
Cheers
Ciao
Def
You could probably get away with a passive heatsink on the SB. The wee Zalman should do the trick, unless it would interfere with your graphics card.
Hiya Cob,
At the moment i still have the older version 8800 gts (640) Not sure if this is going to be a problem
It's a damn close call with the SB/HS as it is now lol
Will have a look at the zalman
Cheers
Ciao
Def
