Funnily enough i put this on the other day for a blast, im gona try that new great effects one, cheers.
Theres an increased draw distance one somewhere as well if i remember, have to hunt it out.
doesnt work for me
Bit weird to install the oblivion grass mod mainly cos i never used imgtool stuff.
I just recently today started adding cars with SAMI it makes replacing models very easy.
I have been getting all the high downloaded models still got ages to go till all stuff is replaced with high poly high texture models tho but so far its paying off the new stuff looks mint ingame.
http://www.thegtaplace.com/downloads/category.php?id=32&order=downloads&sort=desc&st=0
it does for meput the file in c/programfiles/rockstargames/gtasa/data folder
Don't use the increased draw distance, although you might want a bigger draw distance due to poor stock one, the 10X one is just bad:
It really messes up how the game looks, you can see grassland from the desert etc and it just doesn't look ''real'' anymore.
It crashes your game about 3/4th up mt. chilliad, it doesn't like high altitutes.
And all you'll see is empty roads etc it juts looks so bad...
