- 4 Nov 2004
- Norn' Iron'
dmpoole: Check out the DCX2496 also, I use one if these and it's great.
If ya wanted to spend more then you could have got a DEQ2496 also.I very nearly bought the Behringer but I was made to spend double by the PA experts in Sound Control.
I also haven't had a good time with Behringer gear over the years.
Still, the DriveRack is a good unit and it should do everything you want it to, definitely look into limiting first, nothing worse than cooked voicecoils!![]()
At the moment I've got compression & limiting turned off.
I'd like to use the Auto EQ which means plugging a Condensor mic into the front and it sends pink noise to the speakers.
The only problem is it sounds like a jumbo jet landing and theres no way landlords would let me do that for 2 mins.
Theres an excellent DBX forums with all the help I need - thank goodness.
There's no need to do Auto EQ at war volume.Try it with the gains on your amp down a little. Also, I'm not sure about the driverack, but with the DEQ2496, they recommend a certain mic (ECM8000 I think it is) for best results. You may find there's a certain mic intended for the driverack which should give better results...
You really only need it just above speaking level, but in larger rooms you'll want it a bit louder.There is at a cost of £80 but the forums say I can use my SE Condensor.
I'll try the lower volume EQ and apparently I can do a fast one.
I'd also try it outside if possible, as this will show you how your system is without any reflections from walls and ceilings.
Car subs are designed for cars. A cars cabin is smaller than a room, so it's easier to fill with bass (pressurise). Surely it's better to get PA gear as it's designed to fill a room (not car) with sound. A lot (but not all) car subs tend to be a little OTT with their specs also, especially their power ratings... I'm not saying it can't be done, but it's often harder when using gear that's intended for something else.u could get 1 or 2 good car subs + amps then get some good speakers. job done...
im using 2 500w car subs and 1 1000w car sub, which give great bass, also using 8 pers of speakers (300w each)
the 2 500w subs are 4ohm. the 1000w sub is 2ohm... i'm using car amps (TL-1092) and an another car amp for the 1000w sub...What amp are you powering your car subs with? Make sure you check your impedance, as a lot of amps don't like 2 ohm loads...
i have 2 PSU's it wouldn't be good running both amps on 1...Well if you are using an amp for each sub you will be fine - I know sometimes people like to hook up lots of subs to 1 amp. I had 2 car subs up to my Phonic MAX1500 for a while and it used to get pretty warm.
You must have a very good 12v PSU tho, if those are Watts RMS then you could be pulling around 400Amps!![]()
i agree..edit: and you certainly dont need a car amp for a car sub lol
