Hey I'm sure this has been asked tons of times, but I have a small problem, well a big one actually.
My Q6600 has pretty much died
I can get 2 cores to boot, but they aren't running properly and if I use the chip on a board that won't let me disable to cores it just errors before it loads windows.
So I want to send the chip back, and here is where the problems start.
I'm cooling my chip with a TRUE120 and don't have the stock heatsink any more, or the box that it came in. I've got a mates stock cooler that I would send back with it, and um *cough* his receipt. ( i'm not returning it to OCuk )
Do I need the box and does the heatsink match up with the CPU.
Basically, is there any chance I could get away with this?
I can get 2 cores to boot, but they aren't running properly and if I use the chip on a board that won't let me disable to cores it just errors before it loads windows.So I want to send the chip back, and here is where the problems start.
- Didn't get it from the bay, took it from another computer, it worked for 8 months, so its strange that it decided to die. I think i might be screwed...
