- 6 Feb 2008
Ok, I currently have 2 Wharfedale Diamond 9.4 Floorstanding speakers connected to my Yamaha RX-359 using some fairly thick cable. I have just bought the Diamond 9.CM Centre speaker however and need to connect this to my Yamaha Receiver. The problem is that the Receiver only has 'large' connectors for the Front L+R speakers and so the same cable would not fit in the centre connector.
My question is, is it ok to use a different, thinner cable for the centre speaker than the L+R?
What cable would you recommend for it? Cheapish (£2 per metre at the most).
Thanks in advance
Thanks in advance
