Not sure if it's classed as a conspiracy theory, but came across this the other day;
The Great Pyramid
# Only a solid stone mountain could endure the Pyramid's immense weight. And indeed, a flat solid granite mountain happens to be located just beneath the surface of the ground directly under the Pyramid.
# It is built to face true North.
# The Pyramid is located at the exact center of the Earth's land mass. The odds of it's having been built where it is are 1 in 3 billion.
# Amazingly, the outside surface stones are cut within 0.01 (1/100th) inch of perfectly straight and at nearly perfect right angles for all six sides. And they were placed together with an intentional gap between them of 0.02 inch. Modern technology cannot place such 20-ton stones with greater accuracy than those in the Pyramid.
#The height of the Pyramid's apex is 5,812.98 inches, and each side is 9,131 inches from corner to corner (in a straight line). If the circumference of the Pyramid is divided by twice its height (the diameter of a circle is twice the radius), the result is 3.14159, which just happens to be pi.
# Each of the Pyramids four walls, when measured as a straight line, are 9,131 inches, for a total of 36,524 inches. At first glance, this number may not seem significant, but move the decimal point over and you get 365.24. Modern science has shown us that the exact length of the solar year is 365.24 days.
# The average height of land above sea level (Miami being low and the Himalayas being high), as can be measured only by modern-day satellites and computers, happens to be 5,449 inches. That is the exact height of the Pyramid.
# All four sides of the Pyramid are very slightly and evenly bowed in, or concave. This effect, which cannot be detected by looking at the Pyramid from the ground, was discovered around 1940 by a pilot taking aerial photos to check certain measurements. As measured by today's laser instruments, all of these perfectly cut and intentionally bowed stone blocks duplicate exactly the curvature of the earth. The radius of this bow is equal to the radius of the Earth. This radius of curvature is what Newton had long been seeking.
Sauce - http://www.europa.com/~edge/pyramid.html
Where's Mulder and Scully when you need 'em.
The Great Pyramid
