Corsair researches performance increase of 4GB over 2GB of RAM
Permabanned
19 Jun 2007
InURmama
QUOTED :
" DRAM juggler Corsair has just released a document in which it detail internal testing regarding the difference in PC performance when 4 or 2GB of RAM is installed. Named "Gaming Performance Analysis – 4GB vs 2GB," the PDF file includes a small description of the differences memory usage with 32 and 64bit operating systems and, most importantly a test that looks into gaming and multi-tasking performance plus load times when 2 and 4GB of RAM is used in a high-end system.
Corsair conducted the test using Windows Vista Home Premium 64bit with a system consisting of an Intel Core 2 Extreme QX9650, an Asus ROG P965 motherboard (an odd/old choice to say the least), a 320MB GeForce 8800 GTS/ 512MB 8800 GT and 2/4GB of Corsair XMS2 memory. In short, the 4GB system came out on top in practically every test with the biggest difference being seen with task switching and game loading times. As for the conclusion, Corsair states that "4GB of memory is now an essential upgrade for gamers." Not limiting this to gamers, 4GB of RAM is certainly a plus which is becoming more and more relevant and, whether you buy Corsair's memory or not, it almost a must these days. All we need is the money for it. "
May help end the countless 2GB v 4GB threads. ;)
Caporegime
20 Jan 2005
Co Durham
I agree about the graph makes everything look better but 20% gain in company of heros and a 50% gain in crysis minium framerate is good even if it makes no difference to the average framerate.
However I have one problem with that figure and that is if the minium framerate is up 50% then why is the average the same?
Does that mean with 4gb your maximum framerate decreases? It would have to, to be the same average.
However, if true, I would rather see and av of 30fps with the min of 15fps and max of 45fps rather than have an av of 30fps with a min of 10fps and a max of 50fps. Makes for smoother gameplay and less slowdowns.
17 Aug 2003
Woburn Sand Dunes
The Task Switching difference is crazy.
totally believable though. its pretty much what i see - switching out of games and back in is virtually instant and it was anything but on 2gb.
nice post helmut:)
So apart from COH and task switching, the difference is minimal at best...
that is the point of getting more memory lol
Permabanned
OP
19 Jun 2007
InURmama
Thanks, but its only a copy/paste job lol.
I remember the days and not that long ago and even on 1GB of DDR400+last gen CPU's, the PC could take a good 20-30 secs to recover after closing a high end game if lots of AA/Af and 1280x960 (and no there was nothing at fault with the PC, just the HDD going like the clappers).
Sometimes my Desktop was messed up till it cleared.
15 Jun 2007
Manchester
Because that minimum will be at one of the few points the hard drive gets accessed, it may go from say 2 to 4 fps but for 99% of the game the fps will be identical, leaving the average pretty much the same.
Far from an "essential upgrade" when you consider Crysis and FSX are two of the most system-taxing games..
They should've picked something like SupCom with a load of units, probably show more favourable results.
