External? But Which
11 Apr 2003
Notts
Hey all, just looking into getting an external hard drive, and wondering which would be the best to go for, I am currently looking at:
750GB Western Digital WDG1C7500E My Book Premium
Would this be a good buy?
Thanks all!
Jcb33.
have you looked into buying the caddy and drive seperatly? might work out cheaper
I have not, but I can get this drive for £100, buying the internal version is still £90 so not sure it would be worth it... Will the My Book be ok to be switched on and off regularly?
Make sure you umount it properly or shutdown the pc, to get a clean umount.
I wouldnt just turn it off in the middle of a session
I think you beter go read into how SATA+hot plugging works m8.
You obv dont unplug it while its Reading/Writing.
The My Book has No "Look Ahead" Support, probably as its External.
I dont use 1394 its more a Mac thing and your HDD appears as Network Device then.
Any USB or SATA storage device inc Flash works like the screen above.
