NIN - The Slip
Shamelessly stolen off SA, it's too cool not to post:
Step 1: Open Winamp, enqueue your entire NIN folder.
Step 2: Hit Ctrl-K to open plugin selection.
Step 3: Click "DSP/Effect" on the left-hand menu.
Step 4: Highlight "Nullsoft Signal Processing Studio," click "Configure Active Plug-in" at the bottom of the window.
Step 5: Click "Load" on the NSPS control window.
Step 6: Load preset "justin - stupid stereo voice removal.sps"
Step 7: Move slider position to "wet" at top, click "Enable Processing."
Step 8: Choose Your Destiny
It affects the mix of the song you're listening to by removing the center channel and mixing whatever's left in the right and left channels to center mono. It cuts out everything you're used to hearing front-and-center in a song and lets you focus on the hidden bits. It's perfect for The Fragile, so I recommend starting there. I love it on "Just Like You Imagined." You can hear the rest of Mike Garson's piano solo freakout.
Oh yeah, and it has the tendency to make lossy compression sound really ****ty. Forewarned is forearmed.
There's some damn good tracks on this :D
Been listening at work, Head Down is just fantastic, as is Echoplex..
As above - I've been listening to Head Down on repeat play seriously good.
Bit of a bolt from the blue - free and new - bow down to the Trent man!!
Best of luck with that. The last time I looked for that, the sets were going for £150+.
All I'm missing now is WITT, Down In It, yearzeroremixed and Ghosts...
I've got all three versions of March Of The Pigs :D
Yeah, WITT is a bit nasty to get hold of... here's my nin list with cost breakdown
(Packx) means the cds were bought in a set with each other and the total price has been divided equally between them.
Halos
Down In It - £4.70 (Pack2)
Pretty Hate Machine - £3.89
Head Like A Hole - £4.70 (Pack2)
Sin - £4.70 (Pack2)
Broken - £2.70
Fixed - £2.20
March of The Pigs - £4.79 (Pack1)
March of The Pigs (2cd) - £4.70 (Pack2)
The Downward Spiral - £4.79 (Pack1)
Closer To God (2cd) - £4.70 (Pack2)
Further Down the Spiral - £5
The Perfect Drug (Versions) - £2.24
Closure - £27.94 with bootlegs
The Day The World Went Away - £3.70
The Fragile - £3.69
Things Falling Apart - £1.51
And All That Could Have Been (+Still) - £11.50
The Hand that Feeds - £3.51
With Teeth - £4
Only - £4.20
Every Day is Exactly The Same - £3.49
Survivalism - £2.39
Year Zero - £5
Ghosts - £12.13
Misc
Captial G 9" - £3.99
With Teeth/Downward Spiral Bootleg, Painful Convictions, Trent Head CD - With Closure
£139.55 Spent
23/26 Halos
Halos
Sin - £4.70 (Pack2)
Broken - £2.70
Fixed - £2.20
The Fragile - £3.69
With Teeth - £4
Only - £4.20
Survivalism - £2.39
Year Zero - £5
Ghosts - £12.13
Misc
£139.55 Spent
23/26 Halos
out of interest did Capital G get a halo or was it promo only?
update for anybody interested in the 24/96 mix
after some guys over at hydrogenaudio found there were some mixing errors and clipping in the 24/96 version, trent remastered it and has put the new files up for download, including 24bit 96khz FLAC. he also replied personally over at hydrogenaudio:
treznor said:
Gents-
Thanks for the heads up regarding this matter. The corrected files are now posted on our site and if you re-download them they will be the correct ones.
What happened? We mastered this on Friday (5/2) and released it Sunday night. The files went right from mastering to the server without the proper scrutiny (aside from a cursory listen for errors). The last two songs were different because they were redone due to an audible error we did find.
Bottom line: some sort of mastering shenanigans took place.
In addition, there are now 24/96 FLAC files as well as wave files.
BTW, the record was recorded at 24/96 using a Lavry AD122-96MKIII, Antelope's Isochrone OCX clock and mixed in analog through the SSL AWS 900+. We mixed back into Pro Tools through the Lavry as well as a separate rig running at 24/192 using Apogee A/D. The mixes we chose varied song to song based on what sounded best to us.
Trent Reznor
pretty damn good support for a free album if you ask me. Hats off to Mr. Reznor
This is really outstanding. A nice mix of Broken/Downward Spiral feeling to me at least.
And I agree with the repeated listens, it's getting better & better. Great to see Trent back to his ways, Year Zero was a bit poo.
