That's not good at all
and also sounds wrong some how...
Have you done a download new project lately - the first time i got some of the 305* they were showing ppd's of 400ish - was about to post but checked fahinfo first to check out what other were getting - only then did I noticed fahmon was using the wrong points total.
Didn't question it at first as Fahmon usually does an update when it see a new WU for the first time, all the info was showing to the right name type etc all correct, just points was wrong.
my workstation (
[email protected] + affinity) out proforms that with a EVERY unit with two less core, and a lower clock
2651 (1760) - 1067ppd avg (1130 max)
2652 (1148) - 798ppd avg (885 max)
2653 (1760) - 1074ppd avg (1221 max)
3050 (1440) - 944ppd avg (968 max)
3051 (1440) - 929ppd avg (929 max - crunch over a weekend i guess)
3062 (1732) - 986ppd avg (986 max - as above)
3064 (1753) - 953ppd avg (971 max)
3065 (2144) - 841ppd avg (888 max)
Off to check Fahinfo now...
What the time of a single step - use fahlog.txt to check
