yes.you got rid of that awful prosound pav615 then?.
all this Car amp/sub stuff... other than making the house shake with poor quality bass, i cant see the purpose.
money would be better spent on a nicer, sleeker, and better sounding setup
tbh i can't see how u can comment on the sound quality. u are not here so it impossible for u to say.all this Car amp/sub stuff... other than making the house shake with poor quality bass, i cant see the purpose.
i agree car amp isn't needed but i have 3subs so for me cars was the way to go.car amps in the home are a waste of time,
Generally speaking, aren't car amps and speakers over rated and their power-ratings are taking the wee-wee most of the time.
Again just generally speaking.
'super sharp shooter' ?? music?Would be interesting to hear 'super sharp shooter' on it though.
as i said in the other post, the pictures didn't show the layout right. i guess because i used my webcam... its a lage squaw roomOk thats true. However judging by the layout of it, the excessiveness of if, i just cant imagine it sounds too great. Loud i imagine. but not sweet sounding.
so are low end home speakers, subwoofers and amplifiers. its about par for course really. if its a decent brand, then its a different story irrespective of its intended uses
you dont need 3 subs and amps lol. do you have an spl meter? you should invest in one. not only will it enable to set up your system correctly, but it'll also prove your loudness claims and enable us to see just how well your 3 subwoofers really drop. i managed 120db @ 30hz with 1x subwoofer and 1x 2x100w amplifer, 110db at 20hz. i'd love to see what your three subwoofers manage. get one!
. Are you using electronic compensation or are you just getting very complimentary room gain? I plan for sealed woofers, probably with linkwitz transform; but can I expect a lot of room gain? Agree that car subs can be effectively used in the home, main thing to put you off is the naff logos on the cone of some of them
no i'm not, im just pointing out thats it's impossible for someone to comment on the sound quality... only thattrying to say "wow look at my setup". Just trying to brag that you've got something amazing,
3 subs can be an advantage in getting a good overall response, with them tuned for different bands and positioned to reduce room node effects, but I doubt that is what is happening here. How are you powering these 12V car amps anyhow? Set of batteries or an old computer power supply (or something else!). I used to set up things like this with random speakers here and there, good fun but not a likely route to ultimate quality.
James, 8hz is very impressive, especially for a sealed. Are you using electronic compensation or are you just getting very complimentary room gain? I plan for sealed woofers, probably with linkwitz transform; but can I expect a lot of room gain? Agree that car subs can be effectively used in the home, main thing to put you off is the naff logos on the cone of some of them
