Hiper Osiris
ok here we go...
Unpacked the case tonight, very well packed no marks etc
lots of room inside, all finished in black alloy, looks very nice!
I think you might be able to fit in the pa120.3 IF you remove the top fan.
120mm fan on the front draws air in straight over the hard disks, PSU at the bottom with a vent to let hot air hot. Finally, the 2 fans towards the top of the case. I'll be replacing these with LED ones, keeping the originals as spares.
The side window is smoked with a gause like effect over it so it only lets curious people a slight peek at what's inside.
Overall, I'm extremely happy with the case for £80 BARGAIN!
Came well packaged, no marks etc
Lots of room inside & a nice bag of thumbscrews, cable n bobs
The 2 top fans, again, think you could get a pa120.3 in if you removed the top one.
Front of the case. The drives sit behind this & push out the metal flaps that are on springs.
Really nice buttons located on the top.
The extra bits & bobs
Dare I say it, this case looks to be better than some Silverstones.
Obviously their not in the same price bracket or size, but in terms of build quality, design and aesthetics, the Hiper seems better.
That looks to be a really nice case. The build quality looks lovely - the fan grill on top is really nice. Would you be able to see uv tubes okay inside?
Oh, and any idea what the fans that come with it are like?
My Hiper Osiris arrived today :)
I will be swapping over my components into the Osiris on thursday when I have a bit more time.
I've got a couple of uv cathodes that I may put in also.
Ive just ordered one of these too as i couldnt find some new drive rails for my old tt Shark. Looks a mean beast.
The side has a smoked panel with a kind of mesh, but yes you can still see uv tubes. My mate has the Anubis, which is the same & you can see through it.
The fans are Hiper too, so if they are built like the case, can't see why not!
Hope you like it, any chance of some pics too, as I won't be building mine for a few weeks yet :)
