odd sound after new tyre fit
rjk
rjk
OcUK Staff
8 Aug 2007
hi
i got etyres out to fit some nice eagle F1s yesterday - they were great and it seems they did the job to a very high standard
i noticed last night when going round corners that a rattle/clunky sound is coming from the nearside wheel arch
its not scuffing as the car is not lowered.
i was wondering if it would have anything to do with the new tyre fit?
it just seems a coincidence that it happens the day i get new front tyres...
any ideas guys?
I would double check he has tightened the wheel bolts if i were you.
thats the first thing i looked at - i have checked them myself and they are tight
etyres make you witness them tighten the bolts for H&S reasons anyway
thats why im stuck - if its not the bolts - then what the hell is it?
there isn't any spacer/spigot ring needed for your wheel on the hub thats not gone on properly / broken / missing? (you'd only have these if you've replaced the stock wheels generally)
random one but check your power steering fluid level, i've had a similar thing in the past when the PS level was too low
