I think it costs something like 5k just to fix the front driver airbag!
[TW]Fox;11678938 said:It's a 2.0 TDI SE on an 07 with 20k IIRC. I've already valued it. Parkers is rubbish.
Total BS.
However with 8 airbags if most of them have gone off its going to be very expensive just for the airbags.
Wouldn't count the sill as making for a dead car, that could just be the outer sill not inner.
well what extremely reliable system have you valued it with? You can pick them up for under £13k on autotrader with under 20k miles
There's a lot to do with the airbag it is not just a simple replacement. On top of that there is no guarantee it will be good as the manufacturers and Insurers don't pay discount cheap prices.
I was speaking with a dealer and he said the price would be around 4-5k if the driver airbag went off, some guy also had his go off and the insurers wrote it off.
Airbag module / Control module and wiring (perhaps) depends on the car.
£500 for the airbag / £200 for the module and £150 for the wiring, i know this cause i've priced up the work at a ford repair centre, then labour.
Ford... This is not a Ford. There is a different level of safety and cost of equipment.
So lets assume out of the 4 - 5k range you have given me 4k is for parts and 1k for doing the job (which it wouldn't be) thats 11hours at BMW £90/hr...
You think VW parts are going to cost 4.7times more than Ford ones?
