Hi guys,
My Linksys WRT54GL arrived today - awesome service from OCUK as always
Anyways I'm having a bit of trouble getting it all set up
I've upgraded the WRT to Tomato firmware (win!), but I can't for the life of me work out how to basically use the DG834GT as a modem only, with the WRT doing the router stuff.
My setup went like this:
BT socket > Microfilter > Cable > DG834GT... Ethernet cable from port 1 on the DG834GT to the WAN port on the WRT54GL. Then an ethernet cable from port 1 on the WRT to the PC. I'd set the DG834GT to "modem only" mode in the DGTeam firmware.
Initially I could access the WebUI for both the DG (192.168.0.1) and the WRT (192.168.1.1)... But then the connection to the DG died out (unreachable / no ping response from the PC despite the DG still having SYNC) and the WRT's WebUI showed "not connected" on the WAN. I'd set the WRT to "DCHP" btw, which I think is wrong. I'm on UK Online who use PPPoA - but the DG is what's getting SYNC, not the WRT - I just need that to connect to the DG as a modem.
I was just told by a mate to leave the DG834GT in normal router mode, but DISABLE the DHCP and wireless etc and assign the WRT a static IP address, and then use the WRT as a router, ignoring the DG altogether.
Only thing is that part loses me - I'm stuck
Does anyone have any suggestions? I have three routers now, but really only want to use the WRT. I can't afford to shell out another £25 for a standalone modem at the moment, but would consider selling the DG834GT and my old BT Voyager 2091 to recoup the cost at a later date.
In the meantime, can anyone explain in simple-ish terms how to get this working? I HAVE tried Google, btw
Thanks in advance
