I did both the back and front of my original N95 last yr when i sold it on ebay...cost me about £15 for both front and back fascias and they were the official ones. Changing it isnt a problem...theres 4 screws that need to be removed...2 at the top of the slide, underneath the front then when you slide it the other way...theres another 2 screws..once removed just pull it off...simple really
I have a n95 8gb now and the front is full of little scratches so ill probably buy the official nokia fascia for it..sadly i cant give you the name of the place as they are competitors with OCUK
how about if i also want to change the middle part (where the full keypad is), the top part (where the power button is) and the lower part (where the charger/usb is) of the body? is this possible? can you buy original parts for these?
