HTPC. £600 BUDGET
7 Jul 2004
N.W. England
Hello,
I'm going to buy a new 50" plasma for the living room.
I was going to get the 50" panny 1080 70pz but the px is much cheaper and with the extra saved I can build a HTPC.
So £600 budget including vat. vista not needed, but I need a wireless keyboard and mouse.
I need help as it's about 3 years since I'v built a pc and I haven't got a clue what on earth to get.
Many thanks for your help. :)
Unless you need loads of storage space, high res gaming or a case made from forged aluminium you need not spend 600 pounds :)
Ok,
If that's overkill that's great.
As for hdd space I dunno what would you recommend?
I'm very grateful for any recomendations as I'm well behind the times
Ok,
Are you going to rip your dvd's to the hdd?
if so you want about 4GB per film.
SOme cases like this come witha remote and a lcd panel.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-046-SV&groupid=701&catid=7&subcat=1114
But they are expensive. But with a 600 budget should be doable depending on hdd storage.
In the mean time, something like this.
Split the smaller hdd into two sections 40/120 or 60/100 os/music
Then leaves the big harddrive for films
excellently hi specced system there, i was about to spec one up using virtually identical parts excpet i picked the gigabyte 780g board and 2gb of ram not 4.
anyway what ever you choose the 780g chipset micro atx boars are the way the way to go as they have built hd decoders wich alow low power cpus to play full 1080p with out even breaking into a sweat
I run a MoDT with a weedy 1.66GHz core duo mobile and thanks to the modern ATI gfx card 1080p playback use no CPU occupancy at all :)
This way I can run my system completely passive, no fans at all so its dead silent, yet kicks out no heat.
If you want to play games on it that changes everything. You would better going with a c2d and ati graphics card on a normal atx board and a normal case.
Are you really going to play games on it though? I take it you have no table for keyboard/mouse.
FishGUTS said:
What about if I wanted to do a spot of gaming
  • Asus M3A78-EMH HDMI AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard £52.99
  • AMD Athlon 64 X2 Dual Core 4200+ 2.20GHz (Socket AM2) - Retail £34.99
  • OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK) £29.99
  • Samsung SpinPoint F1 500GB SATA-II 16MB Cache - OEM (HD502IJ) £39.99
  • Samsung SH-S203DBEBN 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £13.99
  • Antec Fusion Black HTPC Case - 430HE Watt PSU £104.99
  • Xbox 360 Arcade Games Console £164.99
  • Logitech Cordless Desktop Comfort Laser - Retail (967692-0120) £34.99
  • Sub Total : £476.92
  • Shipping : £12.95
  • VAT : £85.73
  • Total : £575.60
:D
I'm not bothered about games that much if it was possible fine if not no probs.
I don't want a big ugly noisy pc case in my living room:)
If it was my I would get a similar spec to the above and at a latter date add a gfx card and phenom if you really want to game. I wouldn't compromise the media computer components to play games. Do you need a tv card?
What is phenom?
I guess a tv card would mean I could save tv programs to the HD?
If so yes.
