Hi all,
I have a Gigabyte X48 motherboard and the Q9450 45nm quad chip. Ram is DDR3. I'm currently stable at 3.5Ghz, but really think there is more room left for this to go higher. I'm struggling to get it stable at 3.6 as one of my cores fails prime.
Question 1) At 3.6Ghz cores 1, 2 and 3 run fine but core 4 fails prime. This was at 1.3 VCore. I have tried 1.325, 1.337 and also 1.350 vcore. Core 4 takes longer to bomb out now (45 mins as opposed to 2 mins at 1.3Vcore) but going from 1.3 to 1.35 is a pretty high jump in Vcore and i'm suprised it's still not stable? I heard these 45nm chips are sensitive to the volts so don't wanna go higher without some forum advice. Temps are 63 under full load as measured by Real Temp. Idle is 42 degrees. This is on a tuniq tower not watercooling. Should I just keep upping the Vcore or is there something else you can advise.
Question 2) Loadline Calibration - This is a bios setting that I believe is supposed to aid an overclock. At the moment I have this disabled as I believe it does something voltage wise. Should I have this enabled and could it put too much vcore through the chip?
Question 3 - I've heard people refer to CPU PLL voltage. Where is this on a Gigabyte motherboard? Is it "FSB Voltage"?? Or "(G)MCH Voltage"? Any idea for safe values of this on 45nm?
