- 2 May 2007
- Ayrshire, Scotland
Just updated my 8GB - seems to make the phone a little bit snappier but it could be the reformat I did that's responsible for that.
Why exactly do certain brands such as O2 & vodaphone restrict you from updating to the most recent firmware version?
Can anyone confirm if it's available on vodafone branded handsets yet please?
Nope not available on vodafone firmware to answer my own question.
On a separate note does Nemesis Service Suite works on N95 8gb anymore as it wouldn't scan my phone. Just kept on saying error (phone was connected via PC Suite mode and was detected by the computer).
You need to install an older version of the connectivity cable driver. The newest drivers don't work with Nemesis.
That's not strictly true. Vodafone and Orange (to name but two) remove the VoIP functionality from the phone because they don't want you to use it.Firmwares are different for different operators.
They dont restrict you, its just that they are slow in making a firmware for their version of the phone,
Sillly Question
how on earth do i install rotate me on my Nokia N958GB
Tnx
Sillly Question
Tnx
I got my N95 8gb last Friday, and whilst its on an O2 contract, I cant see anything specifically 'O2' about it - there aren't any O2 apps on there that I've noticed. And also, my screen rotates perfectly fine when I put the phone on its side - so would there be any reason to upgrade? I'm perfectly happy with it so far!
Cheers for the advice![]()
how have nokia busted the update app for vista ?
How annoying.
