Hi,
My spec is:
Q6600
Asus Maximus Formula SE x38
4x1GB of ballistix tracer 8500
700w seasonic psu
Basically I came home from work yesterday to see my computer frozen on the 'loading windows vista' splash screen. So I rebooted and then when it is loading vista is flashes a blue screen and then restarts. It never gets into windows.
So I entered setup and returned everything to default and then it boots into windows no problem.
The overclock I had was 333mhz fsb with 9x multiplier. memory at 1066 @2.12v 5-5-5-15 timings. PCI-e speed locked at 100. everything else was at auto.
I've had this overclock for a few months and have never had a problem. I've previously had the fsb at 400 with no problem, so am a bit miffed as to why the overclock is now causing a problem.
Maybe I need to manuallly set the cpu and north bridge voltage, as auto doesn't seem to be doing the trick? Or does the blue screen hint at a possible memory problem (which i am aware isnt unheard off with tracer's on maximus formula boards)?
Thanks
My spec is:
Q6600
700w seasonic psu
Thanks
