Thanks for the info guys i think ill go for the 8400 as i dont see any point in quad core.
great choice m8, that's what I did, the E8400 is an excellent buy and great for gamers, should last you some time, and is said to be a good overclocker if need be. Since it's 45nm it saves on power and heat.
24" Dell E248WFP Silver/Black Widescreen LCD,
512MB BFG Tech 8800GT OC,
Intel Core 2 Duo, E8200, Wolfdale Core,
620W Corsair HX Series Modular SLi PSU,
4GB (2x2GB) Corsair TwinX DDR2 PC2-8500
EVGA NF750i SLI,
I bought the asus p5n-d, see here:
http://forums.overclockers.co.uk/showthread.php?t=17871272
It was the only 750i I could find that made sense on features and price, did you go for it in the end?
Did you get the EVGA? if you did you got ripped off if you got it from the only store I found has it. Nearly twice as much as the asus.
the great thing I love about the asus is it needs no fan on the chipset, due to it's great heatsink. I've been using it for a few weeks now and it's fine and does its job. The evga uses a fan for its heatsink but it has a great layout.
I still say the asus is the better buy. I cannot fault it, the sata ports fear was not an issue since the mobo comes with 2 right angled sata cables and I'm not going SLI in a hurry.
hope the dell is good for you, as it's not tn there's more input lag, but if you're not an fps hardcore gamer it's not much of an issue I guess - and it comes with the increased viewing angle and better colour reproduction - good if you do more with your pc than just gaming. I'm going for the new BenQ v2400w when it arrives in the uk, it's a tn panel 24" around £300. Good thing about tn is you can save yourself around £100.
If you want to go sli in future you will have to upgrade your psu, that 630w corsair won't cut it, even for 2x8800gt.
see
http://www.slizone.com/object/slizone_build_psu.html
if you still run 32bit os then 4gb isn't worth it imo, some fast 2gb in dual channel is good enough, saving on power use and heat. Around 1gb extra isn't worth it imo (around 3gb in 32bit os used). I run 4gb in 4 sticks of geil 6400 but could do fine with 2gb of it, thinking of selling the other 2gb maybe.
8800gt is an excellent buy for gamers at the moment, SLI 2 of them which isn't hard on the pocket. Good for the 24" screen.
