what price we looking at roughly for this?IMO, wait for the a7110 end of June.
You mean the front fan mounts dont line up properly depending on the rad? DamnI really really boubt it will take a 120.2 the front fan mounts don't and have to be drilled to take them.
Its probably easier to cut your own- i found it was at least
The top panel is available elsewhereI bought one for my A70B & it ended up just a waste of money,but it depends on what rad you want to fit,it won't take a PA120.2 for example. Not sure what rad will fit
Better off doing what waso suggested & getting your original top panel cut to fit the rad you want to use. That's what i ended up doing & now houses a PA120.3 up top very nicely
Rob
Hmm, that's the downside. A few google searches have turned up over $500.
So we're looking at >£250.![]()
