No mate it's a 90 day warranty with red octane for the guitar. Controllers normally only have a short warranty due to the nature of use. Have you tried the fixes I posted above. Looking at forums both seem to work well. I'm going to start with the 3M hook one then move the contact board if I have too.
Don't waste your money on the 3M hook trick. I literally just moved the contact board 30 mins ago!!
I used a cheapy stick on hook which came off mid song. And it still moved!
Instead get yourself a T10 Torx Security bit (I can post one as a loan if you want?) and unscrew all 5 screws. Lift the neck slightly and move the contact board a half inch forward.
You can't get it wrong as the contact board sits behind a small plastic lip. Move it infront of that, pop the cover back on and screw the neck back together
ROCK SOLID!!!
Never missed a beat on a quickplay of Sweet Child Expert
(shame my fingers freaked out though
