Need Help Please With Vauxhall NOVA
3 Sep 2007
Surrey
Hi all need some help/pics of the front handbrake cable
i need to fit a new one to a mates car after i snaped :mad:
am i right in beliving its a Y cable as in one cable from handbrake leaver to back then it splits into left and right where it of couse goes to the drums
All the help you'll need :p
/Gets coat.
im sure there used to be a couple of nova owners on here who were used to playing with the car, cant remember their names though.
might be worth heading onto an enthusiasts forum whre you can get more specific help :]
thought off that did a quick google check but too tired and could not realy see a good nova site that and ive got a book off lies on the bay that am bidding on so am not over fussed but thought here would be cheeper then the £5 bay costs :D
not a big job just make sure you get the right side :)(for all it costs just get btoth the long and short cable (lot easier and quicker with shiney new bits for all they cost) can be a pita if its been modded and had discs put on the back iirc you need a mk1 cav short cable but dont quote me on that its been a good 7/8 years since i last lay under a nova
cool cheers bud i belive this is a mk2 nova (if they changed them at all)
Would the dealers know the size when they take the reg no.?
nope only thing that changed was the appearance :)
new front wings headlights bumpers grill (facelift) and the interior trims
everything else was pretty much the same
its a nova, nova tigra and corsa are all the same car mechanically
