- 14 Oct 2007
- newcastle
you wont regret it mate where as in two of three weeks you would have regreted getting the res
for the £300+ you are going to spend on the reserator which are not very good i might add i have had the reserator v1 and the reserator2 you could have
Thermochill PA120.3 120mm Triple Radiator £62.26
Laing DDC 1+ Ultra 18W 12VDC Pump £58.74
D-Tek Fuzion V2 Universal CPU Block £41.11
EK 8800 GTX Full Cover VGA Water Block X2 £115.12
EK Multioption Reservoir 150 £35.24
Masterkleer 7/16" Tubing - 2m £3.50
Total £326.50 inc del
this would be a better watercooling system than the 2 reserators and this was i list i have just thrown together from one website if you shop around i think you could get that to below £300 mate
just to compair i have the same chip need more volts at that speed like 3.4 1.37v
29 31 29 30 idle load 40 38 40 38
they might be quiet but they couldn't keep a beer cold in the arctic
For all those who want to lighten my load of PA120.3's, a certain specialist case builder is taking them in part-ex on a new project he's doing for me.
anyone I know?![]()
ah ok, still should be an interesting project.
Fans have been off for about an hour now and I seem to be settleing at 40c across the cores idle.. (well, light usage) very interesting.
