- 5 Mar 2008
- London
ive seen a article that say's leave a psu unplugged for a week to discharge all the power.It's quite safe IF you follow the precautions - basically leave it switched off and unplugged for a day or so. Rubber gloves/shoes/Spaceman etc. are not required. Do the work while someone else is about, so they can call an ambulance if required.
Wellll...... PC PSU's are not decoupled from the mains which means there is a possibility of death if you don't know what you are doing.
Once When I was testing out my home made valve amp I accidently put my hand on the B+ output of the mains transformer, made my chest tense up and heart race a bit but I guess 900v+ ac volts would do that.
Worst thing I ever seen was someone sit on a live benchrigged PSU for a Moog synth, not sure what was funnier, the look on the guys face as 240V when up his tradesman's, or the fact the the Moog did a little Whoop up in pitch when he did it.
PSU's aren't the best chairs from what I've seen...
You need to think whether risking your life over 30 quid is worth it?
If you know what you are doing like some of the experts here then fair enough but you aren't !
It's like jumping red light, or rail crossing barrier to save a few seconds just to get crushed to pieces.
Sell it, you wil get about 30 quid then get a Seasonic S12 II 500 for 55 quid, I can guarantee that you will be more than happy.
I’ve never had a mains shock worse than that tbh, once opened an antec psu to take some test measurements while it was connected to the mains and somehow touched the live lead out and it made my arm buzz. Did it again last week while I was fitting a silent fan to my HTPC psu, gave the same sensation.
Think I need to start taking more precautions when working with high votages.
Edit: oh btw jimmyb, there is a known issue with some gamexstream psu’s which causes the fan to run at full speed. OCZ will happily replace the psu if yours is suffering from the same issue.
Having 50Hz instead of 60Hz is nice tho, apparently it's less likely to cause a heart attack as it's further away from the average bpm of the human heart...![]()
Their advice was work on the equipment with one hand and keep one hand in your pocket - shocks up one arm only and hopefully your feet are earthed by decent shoes.
PC engineers like to discharge the stored energy in such devices by putting a screwdriver (insulated handle) across the terminals of big capacitors in such devices. Makes a very satisfying bang.
The fact still remains that the big filter caps are going to be highly charged when you open it up. Advice given in here of 'press the power button while the mains lead is removed' isn't going to help that at all.Quite possibly some of the worst 'advice' I've ever read.![]()
