Windows Picture Viewer broke.
Caporegime
3 Jan 2006
Chadderton, Oldham
Why is this happening? Every time I install windows this ends up happening? :confused:
Any ideas on how to fix it?
Using a streamlined or edited windows version? Full install or a repair?
- Pea0n
I guess you could class it as streamlined, sort of, disabled some services, I dont think they are needed for picture gallery though, I disabled windows search/indexing, hybernation file and system restore though.
What services does Picture Gallery depend on?
I'm not sure exactly, but I'd say the best thing would be to try installing it from a normal disk and see if it is still broken there. If it is then try somebody elses media, something may be indirectly related or you may have accidentally disabled a service. all I can recommend at the moment :)
- Pea0n
Well it was working at the start, I dont know what to do, I tried that google picasa or w/e it is as an alternative but its a piece of ****.
