Replace z5500 with what? (home cinema 5.1 please)
Don
21 Oct 2002
Parts Unknown
my mrs is at home and seems to think the speakers are broken (had them for ages now anyway)
if they are, i'm looking to replace them for about £150-180
any suggestions?
5.1 films is most important, but i listen to music on them too (and the odd game)
needs..
optical / coax / 6ch if poss
i loved the thread from your sig :)
"dad my gfx card won't go in"
"stand back son"
may well get another set, is a £180 hi-fi set better though?
The only reciever based 5.1 setup thats close to your budget would be:
Yamaha - AV Package 61: Yamaha RXV361 Reciver + Yamaha NSP110 Speakers.
A quick froogle should find some results; but I dont have any experience as to whether this is a good package or no.
If your serious; then I suggest popping into your local hifi specialist, and having a listen to some budget systems :)
If you were happy with the Z5500, get another one really. How long you had them for? Tried RMA with logitech? Apparently they offer sets at a reduced price if you are out of warranty too.
if its out of warranty they offer you 35% of any products from there online shop
Just a quick suggestion..
How about a second hand av amp @£100 which would do all that you wanted and a nice pair of speakers @£80 to start with (keeps you in budget) then add the rest of the speakers when you can afford it.
Thats what I did and never looked back.
Cheers
