New Bedroom Thead :D Need help With Furniture, Colour, Etc.
14 Apr 2008
Right, Soon I am moving into a much bigger bedroom. I will be doing it all by myself, but have no idea where to look for furniture.
I am looking for a table for the Pc which needs to be ,
160cm Long
70cm Deep
Normal Height.
Now I don't have a clue where to buy (Apart from IKEA, which don't do large ones it seems!) I also Need
A Computer Chair.
So where is a good cheap site to buy these things? Im rubbish at Furniture etc.
And I am getting a bourbon colour carpet, so would you say get the same colour paint for the walls? The bed is being sorted. And the TV & Surround Sound also!
All Help is appreciated.
I've got this desk and couldn't recommend it more. It's 10cm off your desired with and 2cm deeper, but it's easily the best desk I've had, and I've had a few.
Plenty of space to fit stuff on it.
Thats 150cm?
Wow, it doesn't look as big as I thought it would:eek:
I need it for Pc is under the desk.20" Monitor & Mouse & Keyboard and then for Sketching on . Would it be ok you think?
