DON'T DO IT! New cards due VERY soon, 2-3 weeks now. Hold fire and try to be patient!![]()
and, in aswer to your question. it depends on res, the higher the res, the bigger the difference.
If you're not in the market for anything more expensive than the £140 the GTX is going for then go right ahead. Ignore everyone saying to wait - the new cards are going to be at least twice that much so I doubt you'll be in the market for one of those.
The GTX will work fine in your board but just make sure your case can accomodate it - they're very long (approx 10.5").
I think i might just save up and buy a next gen card when the price is right. Thanks guys, i think i will hold out as TBH, the performance i get out my 8800GT is pretty good. I only play COD4 anywayI think i might just save up and buy a next gen card when the price is right.
Does anyone know how the P5K Premium performs in crossfire mode? Most of the top X2 gurus appear to be using the higher spec asus boards.
