bmw stop start?
13 Jan 2006
Wigan
just from dropping my gf off at work i get behind a bus with a poster on the back " if you were using a bmw with stop start technology you wouldnt be using any fuel" or something along those lines, im quite sure it said no fuel.
so, hows that work then?
It's annoying and isn't 100% reliable to startup IME, waste of time, also on the diesels, doesn't this ruin turbos?
turbos are really meant to be left idling a couple of minutes after they've been spooling before shutting the engine off
How does it work? A friend of mine was buying his wife a new Mini with this feature (I think) and she rides the clutch. He was worried it'd cut out on her half way round a roundabout or something.
That wont happen, dont worry. The car has to be stationary.
Ah, cool. They've probably got it by now anyway. Been a whilse since I spoke to them. Wish I could just buy cars like him. Has a new M3. 2000 miles = new tyres :eek:
Surely a car doesn't use that much petrol when idling?
Well, fuel has to be put into the engine to keep it turning over, so it will certainly use some.
How much is used to start it?
Probably not very much at all. I would have thought the battery takes most of the strain, and the battery is only charged when the car is coasting or braking (another Efficient Dynamics technology).
I think the 62mpg (with a not too shabby 140bhp) of the 118d should show that at least some of this technology is working. The CO2 is similar to a Prius too. :)
Personally i think its a bad idea, stop / start is always bad for an engine + excessive wear on components etc.
In the past I would agree, but with modern tolerances, materials and lubrications, it's not really a problem. Not sure about turbos though as I have no idea about them.
Also as it's manufacturer fitted, they deem it to be within tolerances of what the engine/turbos/startermotor can take.
I suppose if the engine has an electric oil pump to keep the oil pumping around the turbo when the engine shuts down then it isn't really an issue.
With the above in place things like the starter motor is bound to wear out quicker, however how i have not idea about how much quicker, how much more efficient is the Ed model vs. the normal one?
Was reading about this the other day and thinking about wear issues as everyone has already said.
The engine will only stop when in neutral with the clutch engaged i think?, so if you didn't want the car to stop/start you could easily just leave it in gear.
The other similar feature being introduced with stop start is the Intelligent Alternator Control (IAC), which from what i gather stops the alternator from loading the engine, and only puts load on the engine when the battery actually requires charging, as well as using the energy generated by the engine on over-run, either under braking, or downhill, to charge the battery.
Sounds more like an opportunity to teach her how to drive properly.
That was his final words on the matter. If it did cut the engine whilst riding the clutch she'd have little braking power and if she had an accident then lesson learnt hopefully. He said he's had enough of trying to get her to drive properly.
Yeah great you save all that fuel but that battery isn't going to last as long with all those additional cycles, surely?
