Cleaning bikes - Handy Tips
Man of Honour
1 Nov 2007
Christchurch UK
Heys guys
Just thought I'd post what I've learnt over 20 years of biking about looking after ya bike.. maybe some of you have tips as well, most of it might be obvious, but I find the below the best way to keep your bike both looking good and not turning into a piece of junk within a year. A well looked after bike continues to feel like new.. and poorly maintained one, even just the basics will feel like a barge.
Worst thing you can ever do to a bike to clean it is the dreaded jet wash (garages do this to 2nd hand machines, but it's repeated use thats bad). It does clean really well and quickly, but it also removes any protection / lube on your bike and especially over winter your bike will corrode extra fast, probably faster than not cleaning it at all. Also knock on effect is pretty much every fastener will start to sieze, and you'll be forced to drill out bolts etc when needing maint.
I remember a mechanic saying you can always tell a bike thats been jet washed all it's life, everything is dry (and most bolts etc are rounded off as a result)
In the summer I try to avoid soap and water on bike and maybe only use this once every 3 weeks or so. In between I just spend 30mins with a small rag and a large can of WD40. Just spray onto rag and wipe everything over (making sure you avoid tyres / discs) and you'll be amazed at how clean bike looks, a thin oil like WD40 is actually best thing for removing other oil. Best of all it's then got a protective layer to protect against alloys oxidising / rust and makes it even easier to clean next time. The plastic body work just gets a quick and easy wipe over with 'Mer' for just a basic shine :)
There is a couple of other products on market even better than WD40 for protecting, name slips me but they were developed for planes in US navy and leave a much longer lasting film of protection :)
When you do get the hose out on bike don't go crazy with high pressure on lubed areas, rad grill or instruments / headlights. One thing to do is to put hose pipe on a hard jet and stuff it into the sides of your calipers to clean crud out. It's not enough to harm seals or strip lube from slider pin, but enough to just shift the crud / brake dust build up... and so far I've found this the best way to minimize having to strip your brake calipers so often for cleaning / lube)
When ever you remove any bolt / fastener on your bike apply copper grease / lube / slip to threaded parts before putting back. Means next time you remove it, no siezing. I think there are various anti sieze pastes about made from alum as well. (be careful on highly torqued parts as you need a little extra torque to offset the effect of compound)
After cleaning bike I always lube / adjust chain / check tyre pressures (for street stick with 36f 42r, lower pressures are for hardcore riders who require extra grip and heat in tyre, your tread with evaporate like this though and just not needed for road riding and most the time your tyre will be too soft as your temps will fall in traffic and slow handling). Also go around all moving joints like footpegs / gear shift bushes / levers with a light synthetic lube (I forgotten the one I use but it's branded 'high temperature lube), this means it doesn't just burn up if close to engine. I then go around and just do a visual on bolts etc, and also check for play in bearings on axles and headrace. Worth doing this as I've had a wheel litrally collapse on a ZX12 before from bearing giving way, and it's a scary thing.
Last thing all the above gives you is a wonderful smell, you walk into garage in morning and you can smell hot WD40.. hmhmhmhmhmhm, now where's the bike sex thread lol
Used to use Muc-off on the Firestorm to clean it. Worked a treat, spray on, leave a few mins then use a wet sponge to work it in. Wash off with a hose pipe, et voila a nice clean motorbike.
My NC30 i used to clean with Mr Sheen. shifts shines and shields in seconds! Amazed how well it cleaned splatted flies of the fairing.
gotta be careful though, a lot of these hardcore cleaning potions then leave nothing but bare metal with no lasting protection... you end up with dry / corroded bike in no time.
Yep, thats the best £30 I ever spent on my bike. I rode my Tiger all through winter, with just 2 washes and applications of ACF50. When it was all washed off the bike underneath looked in showroom condition. Amazing stuff.
edit - to emphasis how good it was, I had to replace an indicator and forgot to apply acf50 to the bolts. They were rusty as hell a couple of months later, whereas everything which had been treated was as good as new.
Some good tips there. :)
I use gunk in a spray bottle with everything washed of then liberal splashings of WD40 and then wiped over with an oily rag for protection. I find this takes about 30min and is enough to keep it clean and rust free.
a mod should sticky the guide, bikes aren't so obvious when it comes to cleaning.
Doesn't the propellant in wd40 perish rubber seals etc though? I thought that was why people advise against using it on chains, even as a stop gap, because it ruins the seals if it's an 'o' ring chain for instance. It probably does add a layer of protection to metal parts such as the swing arm, but other than that, I can't think where else i'd use it without risking doing more harm than good. I guess though, it would be better than jet washing all the lube off or just not cleaning it at all.
No dont use WD40 on chain, buy proper chain cleaner and chain lube for that. I personally use Wurth Chain and Brake cleaner and Wurth Dry Chain Lube, great stuff.
I dunno, I clean everything really with it that is not bodywork, wipe the underside of bike even though plastic, hugger, foothangars, swingarm, engine casing, headstock / top of forks, wheel rims (it cleans these really well) etc etc. By the time you've given fairing / tank / seat unit a quick wipe over / polish the bike is gleaming, and not one drop of water or soap to be seen.
WD40 poses no harm on these kinds of things and a lot better than pointing a high psi jet wash at your poor bike.. they use high psi water for crowd control, why beat your bike to death with it :). I first started the WD40 obsession about 5 yrs back when my neighbour who was a ex yamaha race team mechanic told me to do it rather than washing.. never looked back.
Like you say though, best not wipe it near rubber bushings / seals just to be on safe side (there are not that many of them on a bike)
Deffo not spray on chain, thats job for proper cleaner / wax / lube. Must admit never cleaned a chain in my life, they usually just plain worn out at about 10k miles. Never ride on a dodgy old chain, when they snap at high speed it's the scariest moment of your life with a real possibility of locking your rear wheel or wrapping around your leg. Maybe you can get away with it on less powerful bikes, but if you have over 100bhp, don't risk your life for the sake of 80 quid, buy a new chain every 10k miles. (check ya chain for tightspots, siezed links and check for hooking on sprockets, you should not be able to pull chain back from rear of sprocket with fingers...but prolly best to change chain / sprockets together as they don't add much more cost)
Gonna invest in some ACF50 at end of summer to see bike through winter commuting, everyone raves about it.
I just clean mine with a hose and brush, then spray chain wax to all the moving parts.
Then put it back in the shed. ;)
heh, well that will work.. but have to commute on mine 14-50 miles a day rain or shine :(
dam fair weather bikers ;);) (i'd like to be one tbh)
I wish I only did 14 miles! I commute 100 miles a day on the bike. Clocked up 5.5k so far since Christmas.
Still goes in the shed overnight, unless I'm being particuarly lazy.
Me and my brother always use the following technique which kept older GSXR600's in showroom condition, despite their instarot (tm) finish.
But I think it's different if you are a heavy daily commuter, you do need to keep it 'oiled' to protect from the elements, but if you are more of a fair weather biker..
1. Spray calipers/around the swingarm area/wheels with autoglym motorcycle cleaner or Muckoff
2. Use a 'basil' brush or similar to brush all over the calipers and in and around the rear shock, and rear sprocket, rinse as you go.
3. Use normal car shampoo and clean all over the bike, it may require some more muckoff/AG Motorcycle cleaner to get the wheels uber clean.
5. Every few washes, get in there with the jet wash, around the calipers/read shock, don't go too close, and don't go mad..
4. dry off, and lube the chain (use a z-oiler or similar brush/lube clip on item and it takes 2 mins with no mess), then spray some WD40 or similar on a rag, and lightly 'season' any unprotected metal parts, I don't go mad with the WD40, as I've heard too many stories of it ruining seals, dissolving grease in bearings etc and found it attracts the dirt into nooks and crannies unnecessarily..
Dam, thats pretty long way for commute... I done 7k miles since just before xmas, but thats mainly hooning around countryside at weekends :)
Thanks for the tips. I think my CBR is due a good clean. Im trying to get my back wheel off, need to give the swing arm a really good clean. Just cant get anything in to give it a proper scrub. I have used WD 40 a few times to clean my bike, it does wonders for parts like the exhaust and swingarm.
Ooh good thread, i've just ordered a few things before reading this, including the ACF50 or whatnot, chain/brake cleaner, wurth dry lube, and maybe some bungees and one of those things to prevent the side stand sinking into a field. :)
Now I just need the bike!
