I know its got different memory chips etc... but it doesn't matter how you dress it up, at the end of the day its still an 8800 GTS 512mb, basically all they have done with the 8800 GTS 512mb cores, is stick them on longer PCB's, and added the extra power connector/SLi connector, how does that make it a new card lol.
I think you've said this about 250,000 times and it's really starting to get irritating. Here are the specifications and the 2 cheapest products from overclockers.
£223
http://www.overclockers.co.uk/showp...MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
GeForce 8800 GTX core running at 600MHz
- Shader Clock Speed of 1350MHz
- 768MB GDDR3 Memory running at 1900MHz
- 384-Bit Memory Interface
- 128 Stream Processors
- Texture Fill Rate: 36.8 billion/sec
- Memory Bandwidth: 86.4GB/s
£188
http://www.overclockers.co.uk/showp... GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
- GeForce 9800 GTX core running at 675MHz
- Shader Clock Speed of 1688MHz
- 512MB GDDR3 Memory running at 2200MHz
- 256-Bit Memory Interface
Here are some quotes from reviews with regards to the 9800GTX in comparison to the 8800GTX
Call of duty 4
The 9800 GTX is not too far behind the X2 and actually ties with the much more expensive 8800 Ultra. Moving to SLI performance we see that the 9800 GTX is once again very close in performance to the Ultra with only a single frame per second separating the two systems on average and minimum framerates.
Colin Mcrae Dirt- Positive comment
has similar performance trends to Call of Duty with the GX2 leading the X2 which is followed by the GTX and Ultra. Looking specifically at the Ultra against the new GTX we see that once again the performance of the two cards is near identical, including when we enable SLI.
Gears of War- Negative Comment
Looking next to the GTX performance we see for the first time a significant gap between it and the Ultra. We believe the reason for this is that the extremely high settings used in this test are exposing a limitation of GTX, whether it be the amount of memory available or ability to process large volumes of data in comparison to the Ultra
Lost Planet- Positive comment
we see the new 9800GTX performing at a near identical level to the 3870 X2, if we were using a reference speed X2 then the GTX may even have a slight lead in overall performance at this setting. There is however a small gap between the GTX and Ultra with the GX2 once again out in front.
Half life 2- Positive comment
Once again the 9800 GTX is able to put in some very decent performance figures, despite the very demanding settings used in this game. Whilst the average frames per second statistic is significantly lower than the GX2 or X2 the minimum performance is not far off and other than the occasional drop below twenty-five frames per second the GTX still provided an enjoyable Half-Life 2 experience.
Oblivion- 9800GTX OUTPERFORMING THE ULTRA HERE
When we compare the 3870 X2 to the GTX and Ultra cards we see that Oblivion is another title where the ATI based card performs very well. Another interesting aspect of the results is that at our tested settings the GTX is able to slightly outperform the Ultra both in single card operation and in SLI. The Gainward GX2 is of course well ahead of the other cards in this test as well.
Assasins creed - 9800GTX OUTPERFORMING THE ULTRA HERE
As the graph above shows, Assassins Creed is another title where the new GTX is able to perform at a similar level to the now aging Ultra, in fact the GTX is able to slightly outperform the older part
Read this and weap...
Both BFG and Zotac cards perform very well compared to the 8800 Ultra and they generally manage to exceed the performance of the older, more expensive part. There are a few occasions, such as Gears of War, where the Ultra is able to perform noticeably better but these scenarios are few and far between. SLI scaling is also working well and as with the single card results the GTX is never far away from the UItra.
Where the 9800 GTX really excels when compared to the 8800 GTX and 3870 series is with high-definition playback. When sitting down to watch a movie the ATI card performs better but lacks the ability to have Aero running at the same time, something the 9800 can do with ease. The older 8800 does not accelerate HD so there is really no contest. Turning on the picture in picture functionality gives the performance edge to Nvidia.
Core temperature of the 9800 GTX was very impressive with an idle result of approximately 58c on both cards, increasing to 65c under full load. Throughout our testing we were also pleased to see that there were no driver related crashes or image quality issues, everything worked exactly as expected.
The final consideration of the 9800 GTX is the retail price. With models starting at around £190 in the UK this is around £30 cheaper than a 8800 GTX and anywhere between £50 and £100 less than the Ultra, if you can still find one in stock. Considering the excellent performance and additional features of the 9800 series that makes the new GTX a must buy product in its price range.
NOW SOMEONE PLEASE TELL ME WHY THIS CARD IS GETTING SLATED!? sorry for the caps but im just lost, ive given examples in two different posts from 2 different reviews which both supports the card...Sure it's not what we expected but the GTX was around £400 upon release and this is half that price
Review,there are 22 pages, this is an in depth review
http://www.driverheaven.net/reviews.php?reviewid=544&pageid=1
Here is another nice round up of it
http://www.hothardware.com/Articles/NVIDIA_GeForce_9800_GTX_RoundUp_BFG_EVGA_Zogis/?page=9
In conclusion the 9800GTX =
+ Better Overclocking
+ Better temperatures
+ Better speeds at 1650x1050 and more times than less higher resolutions
+ G92 core
+ Cheaper
+ Superior high definition playback
+ Lower power consumption
8800GTX =
+ Better if played at a higher resolution than 1650x1050 with at least 4xAA
- Not as overclockable
- Higher temperatures
- Old G90 core
- More expensive
- Inferior high definition playback
- Higher power consumption
At £190 the 9800GTX is a good buy but if I was purchasing now I'd wait for the next gen cards to see if there will be further price drops. Sorry to rant on but I like to back up my opinions with FACTS unlike some others.
My 9800GTX is currently clocked at 825/2020/2300 and reaches highs of 60C with the fan speed at 90%
Peace out
Gustov
