Good Set of Spanners Required
3 Jan 2006
Elgin
doing some servicing on my car and although i have a good draper socket set and torque wrench i find that my spanners are naff :(
so im looking for a good make and where to buy?
ideally id like the open ended / ratchet type
any one suggest some good sets?
Halfords Pro range are good for the money. Keep the reciept and if they break just take them back.
Another vote for the big Halfords spanner sets. I have the set that always seems to be discounted from £150 to £100 in the stores and it is bombproof and has pretty well all the bits that I need for the car. I just have a couple of Torqueleader torque wrenches and a set of laser flexi head ratchet spanners to complete things, not really anything else needed for the big jobs :). Tool chests are great, got a full 2 piece Clarke chest job with the wheels etc for Chrimbo. Only manages to hold about half my tools but makse things so much easier to find over digging around multiple toolboxes.
yeah a new set of spanners and i should have everything i need to do pretty much anything on the car :)
even got access to a 2 tonne engine lift ;)
a £150 spanner set?
something like this :)
Ratchet spanners, you spanner.
Shut up:D:o Matt's link doesn't mention ratchet spanners:p
No point getting the Halfords Pro one though if you don't need all the sockets? What about a Britool set? They're good.
Torch [P4];11802797 said:
do you find that the flexi head ones are easy to control on high torque nuts ?
Seem fine, but as I don't have a reciept for mine I don't fancy wrecking the ratchet in them so on bolts that need to be really tight I tend to swap to a long handled ring spanner.
I thought I was the only one!
I bought a halfords socket set cause they were cheap, thinking they were going to crap but they turned out to be very good for the money.
highly recommended
I have a mechanic friend who swears by snap on stuff, he wont use anything else.
this is in the same mindset as people who think vw are a prestige brand,
britool, teng, draper expert,mac, Irwin, halfords professional and many other brands are as good if not better than snap on but just without the "added snap on tax"
i usually order teng gear for my work's tool box.
i have the same flexi head rachet set by halfords as posted above
http://www.halfords.com/webapp/wcs/...6864_crumb_33958-76859_parentcategoryrn_76864
highly reccomended, were a god send for when i replaced the clutch on the merc, downpipe bolts and clutch slave cylinder mounting bolts are impossible to get to with a ratchet and only a few degrees of movement with a normal spanner.AFAIR these spanners work with as little as 5 degrees of turn
however it is lacking the 11mm 16mm and 18mm which seem to be more common on french cars.
as for halfords warrentys i have never needed the reciept, albeit only once when i broke a torx bit by using a 1/4" drive bit on a 1/2" 3 foot long breaker bar :/ hardly part failure and more me just being a ham fisted fool.
just took it in and they swapped it there and then.
Regards
Andy
